The key here is the first part - the board used on a jackpot already has a USB port.
I was going to ask the same question about the bad info.
Of course it was AI hallucinating.
Glad you got it sorted out.
I had a similar if not the same issue whereby I kept getting the message " waiting on connection " Problem was I did not click the " DISCONNECT " button first that takes you right back to the Web Installer’s front page. Then I simply hit the “CONNECT” button and followed the instructions and then the code started to load onto the ESP32.
