I found an error on my assignments but still not working… I have this pinout also, for GT2560 and is the same like yours.
Maybe the problem is in the values in previous section of cpu_map file? I just copy the file just to check, I dont know what else could I do …
#ifdef CPU_MAP_GT2560_REV_A // (Arduino Mega 2560) with GT2560 Rev. A Board
#include “nuts_bolts.h”
// Serial port interrupt vectors
#define SERIAL_RX USART0_RX_vect
#define SERIAL_UDRE USART0_UDRE_vect
// Define ports and pins
#define DDR(port) DDR##port
#define _DDR(port) DDR(port)
#define PORT(port) PORT##port
#define _PORT(port) PORT(port)
#define PIN(pin) PIN##pin
#define _PIN(pin) PIN(pin)
// Define step pulse output pins.
#define STEP_PORT_0 A
#define STEP_PORT_1 C
#define STEP_PORT_2 C
#if N_AXIS > 3
#define STEP_PORT_3 L // Axis number 4 (Ramps E0)
#endif
#if N_AXIS > 4
#define STEP_PORT_4 L // Axis number 5 (Ramps E1)
#endif
#if N_AXIS > 5
#define STEP_PORT_5 L // Axis number 6 (Ramps Aux-3 D49)
#endif
#define STEP_BIT_0 3 // X Step
#define STEP_BIT_1 6 // Y Step
#define STEP_BIT_2 0 // Z Step
#if N_AXIS > 3
#define STEP_BIT_3 6 // Axis number 4 Step
#endif
#if N_AXIS > 4
#define STEP_BIT_4 0 // Axis number 5 Step
#endif
#if N_AXIS > 5
#define STEP_BIT_5 0 // Axis number 6 Step
#endif
#define STEP_BIT(i) STEP_BIT##i
#define STEP_BIT(i) _STEP_BIT(i)
#define STEP_DDR(i) DDR(STEP_PORT##i)
#define _STEP_PORT(i) PORT(STEP_PORT##i)
#define STEP_PORT(i) _STEP_PORT(i)
#define STEP_PIN(i) PIN(STEP_PORT##i)
// Define step direction output pins.
#define DIRECTION_PORT_0 A // X_Dir
#define DIRECTION_PORT_1 C // Y_Dir
#define DIRECTION_PORT_2 G // Z_Dir
#if N_AXIS > 3
#define DIRECTION_PORT_3 L // Axis number 4 E0_Dir
#endif
#if N_AXIS > 4
#define DIRECTION_PORT_4 L // Axis number 5 E1_Dir
#endif
#if N_AXIS > 5
#define DIRECTION_PORT_5 B // Axis number 6 (Ramps Aux-3 D51)
#endif
#define DIRECTION_BIT_0 1 // X Dir
#define DIRECTION_BIT_1 4 // Y Dir
#define DIRECTION_BIT_2 2 // Z Dir
#if N_AXIS > 3
#define DIRECTION_BIT_3 4 // Axis number 4 Dir - Pin D28
#endif
#if N_AXIS > 4
#define DIRECTION_BIT_4 2 // Axis number 5 Dir - Pin D34
#endif
#if N_AXIS > 5
#define DIRECTION_BIT_5 2 // Axis number 6 Dir - Pin D51
#endif
#define DIRECTION_BIT(i) DIRECTION_BIT##i
#define DIRECTION_BIT(i) _DIRECTION_BIT(i)
#define DIRECTION_DDR(i) DDR(DIRECTION_PORT##i)
#define _DIRECTION_PORT(i) PORT(DIRECTION_PORT##i)
#define DIRECTION_PORT(i) _DIRECTION_PORT(i)
#define DIRECTION_PIN(i) PIN(DIRECTION_PORT##i)
// Define stepper driver enable/disable output pin.
#define STEPPER_DISABLE_PORT_0 A
#define STEPPER_DISABLE_PORT_1 A
#define STEPPER_DISABLE_PORT_2 C
#if N_AXIS > 3
#define STEPPER_DISABLE_PORT_3 G // Axis number 4 (Ramps E0)
#endif
#if N_AXIS > 4
#define STEPPER_DISABLE_PORT_4 L // Axis number 5 (Ramps E1)
#endif
#if N_AXIS > 5
#define STEPPER_DISABLE_PORT_5 B // Axis number 5 (Ramps Aux-3 D53)
#endif
#define STEPPER_DISABLE_BIT_0 5 // X Enable - Pin D38
#define STEPPER_DISABLE_BIT_1 7 // Y Enable - Pin A2
#define STEPPER_DISABLE_BIT_2 2 // Z Enable - Pin A8
#if N_AXIS > 3
#define STEPPER_DISABLE_BIT_3 0 // Axis number 4 Step - Pin D24
#endif
#if N_AXIS > 4
#define STEPPER_DISABLE_BIT_4 1 // Axis number 5 Step - Pin D30
#endif
#if N_AXIS > 5
#define STEPPER_DISABLE_BIT_5 0 // Axis number 5 Step - Pin D53
#endif
#define STEPPER_DISABLE_BIT(i) STEPPER_DISABLE_BIT_##i
#define STEPPER_DISABLE_DDR(i) DDR(STEPPER_DISABLE_PORT##i)
#define STEPPER_DISABLE_PORT(i) PORT(STEPPER_DISABLE_PORT##i)
#define STEPPER_DISABLE_PIN(i) PIN(STEPPER_DISABLE_PORT##i)
// Define homing/hard limit switch input pins and limit interrupt vectors.
#define MIN_LIMIT_PORT_0 H
#define MIN_LIMIT_PORT_1 H
#define MIN_LIMIT_PORT_2 H
#if N_AXIS > 3
#define MIN_LIMIT_PORT_3 H
#endif
#if N_AXIS > 4
#define MIN_LIMIT_PORT_4 H
#endif
#if N_AXIS > 5
#define MIN_LIMIT_PORT_5 F // (Ramps Aux-1 D57)
#endif
#define MIN_LIMIT_BIT_0 7 // X Limit Min - Random (no known mapping)
#define MIN_LIMIT_BIT_1 7 // Y Limit Min - Random (no known mapping)
#define MIN_LIMIT_BIT_2 7 // Z Limit Min - Random (no known mapping)
#if N_AXIS > 3
#define MIN_LIMIT_BIT_3 7 // Axis number 4 : Random (no known mapping)
#endif
#if N_AXIS > 4
#define MIN_LIMIT_BIT_4 7 // Axis number 5 : Random (no known mapping)
#endif
#if N_AXIS > 5
#define MIN_LIMIT_BIT_5 3 // Axis number 6 : RAMPS AUX2 pin D57
#endif
#define MIN_LIMIT_BIT(i) MIN_LIMIT_BIT##i
#define MIN_LIMIT_BIT(i) _MIN_LIMIT_BIT(i)
#define MIN_LIMIT_DDR(i) DDR(MIN_LIMIT_PORT##i)
#define MIN_LIMIT_PORT(i) PORT(MIN_LIMIT_PORT##i)
#define MIN_LIMIT_PIN(i) PIN(MIN_LIMIT_PORT##i)
#define MAX_LIMIT_PORT_0 A
#define MAX_LIMIT_PORT_1 A
#define MAX_LIMIT_PORT_2 C
#if N_AXIS > 3
#define MAX_LIMIT_PORT_3 A
#endif
#if N_AXIS > 4
#define MAX_LIMIT_PORT_4 A
#endif
#if N_AXIS > 5
#define MAX_LIMIT_PORT_5 F // (Ramps Aux-3 D58)
#endif
#define MAX_LIMIT_BIT_0 0 // X Limit Max - X_Min
#define MAX_LIMIT_BIT_1 4 // Y Limit Max - Y_Min
#define MAX_LIMIT_BIT_2 5 // Z Limit Max - Z_Max
#if N_AXIS > 3
#define MAX_LIMIT_BIT_3 2 // Axis number 4 : X_Max
#endif
#if N_AXIS > 4
#define MAX_LIMIT_BIT_4 6 // Axis number 5 : Y_Max
#endif
#if N_AXIS > 5
#define MAX_LIMIT_BIT_5 4 // Axis number 6 : RAMPS AUX2 pin D58
#endif
#define MAX_LIMIT_BIT(i) MAX_LIMIT_BIT##i
#define MAX_LIMIT_BIT(i) _MAX_LIMIT_BIT(i)
#define MAX_LIMIT_DDR(i) DDR(MAX_LIMIT_PORT##i)
#define MAX_LIMIT_PORT(i) PORT(MAX_LIMIT_PORT##i)
#define MAX_LIMIT_PIN(i) PIN(MAX_LIMIT_PORT##i)
// #define LIMIT_INT PCIE0 // Pin change interrupt enable pin
// #define LIMIT_INT_vect PCINT0_vect
// #define LIMIT_PCMSK PCMSK0 // Pin change interrupt register
// #define LIMIT_MASK ((1<<X_LIMIT_BIT)|(1<<Y_LIMIT_BIT)|(1<<Z_LIMIT_BIT)) // All limit bits
#define DISABLE_HW_LIMITS_INTERUPT
// Define spindle enable and spindle direction output pins.
#define SPINDLE_ENABLE_DDR DDRG
#define SPINDLE_ENABLE_PORT PORTG
#define SPINDLE_ENABLE_BIT 5 // MEGA2560 Digital Pin 4 - Ramps 1.4 Servo 4 Signal pin (D4)
#define SPINDLE_DIRECTION_DDR DDRE
#define SPINDLE_DIRECTION_PORT PORTE
#define SPINDLE_DIRECTION_BIT 3 // MEGA2560 Digital Pin 5 - Ramps 1.4 Servo 3 Signal pin (D5)
// Define flood and mist coolant enable output pins.
#define COOLANT_FLOOD_DDR DDRE
#define COOLANT_FLOOD_PORT PORTE
#define COOLANT_FLOOD_BIT 4 // MEGA2560 Digital Pin 10 - HEAT-0
#define COOLANT_MIST_DDR DDRE
#define COOLANT_MIST_PORT PORTE
#define COOLANT_MIST_BIT 5 // MEGA2560 Digital Pin 9 - HEAT-1
// Define user-control CONTROLs (cycle start, reset, feed hold) input pins.
// NOTE: All CONTROLs pins must be on the same port and not on a port with other input pins (limits).
#define CONTROL_DDR DDRK
#define CONTROL_PIN PINK
#define CONTROL_PORT PORTK
#define CONTROL_RESET_BIT 1 // Pin A9 - RAMPS Aux 2 Port
#define CONTROL_FEED_HOLD_BIT 2 // Pin A10 - RAMPS Aux 2 Port
#define CONTROL_CYCLE_START_BIT 3 // Pin A11 - RAMPS Aux 2 Port
#define CONTROL_SAFETY_DOOR_BIT 4 // Pin A12 - RAMPS Aux 2 Port
#define CONTROL_INT PCIE2 // Pin change interrupt enable pin
#define CONTROL_INT_vect PCINT2_vect
#define CONTROL_PCMSK PCMSK2 // Pin change interrupt register
#define CONTROL_MASK ((1<<CONTROL_RESET_BIT)|(1<<CONTROL_FEED_HOLD_BIT)|(1<<CONTROL_CYCLE_START_BIT)|(1<<CONTROL_SAFETY_DOOR_BIT))
// Define probe switch input pin.
#define PROBE_DDR DDRC
#define PROBE_PIN PINC
#define PROBE_PORT PORTC
#define PROBE_BIT 7 // GT2560 Rev A Z_Min(30)
#define PROBE_MASK (1<<PROBE_BIT)
// Advanced Configuration Below You should not need to touch these variables
// Set Timer up to use TIMER5B which is attached to Digital Pin 44 - Ramps 1.4 AUX-2
#define SPINDLE_PWM_MAX_VALUE 255 // Translates to about 1.9 kHz PWM frequency at 1/8 prescaler
#ifndef SPINDLE_PWM_MIN_VALUE
#define SPINDLE_PWM_MIN_VALUE 1 // Must be greater than zero.
#endif
#define SPINDLE_PWM_OFF_VALUE 0
#define SPINDLE_PWM_RANGE (SPINDLE_PWM_MAX_VALUE-SPINDLE_PWM_MIN_VALUE)
//Control Digital Pin 6 which is Servo 2 signal pin on Ramps 1.4 board
#define SPINDLE_TCCRA_REGISTER TCCR5A
#define SPINDLE_TCCRB_REGISTER TCCR5B
#define SPINDLE_OCR_REGISTER OCR0B //OCR5C ***********************
#define SPINDLE_COMB_BIT COM0B1 //COM5C1
// 1/8 Prescaler, 16-bit Fast PWM mode
#define SPINDLE_TCCRA_INIT_MASK ((1<<WGM40) | (1<<WGM41))
#define SPINDLE_TCCRB_INIT_MASK ((1<<WGM42) | (1<<WGM43) | (1<<CS41))
#define SPINDLE_OCRA_REGISTER OCR5C //A // 16-bit Fast PWM mode requires top reset value stored here.
#define SPINDLE_OCRA_TOP_VALUE 255 // 0x0400 // PWM counter reset value. Should be the same as PWM_MAX_VALUE in hex.
// Define spindle output pins.
#define SPINDLE_PWM_DDR DDRG //DDRL ****************************
#define SPINDLE_PWM_PORT PORTG //PORTL ****************************
#define SPINDLE_PWM_BIT 5 // MEGA2560 Digital Pin 44
#endif
#endif
