What does everyone use for a gcode sender? I am using estlcam to repetier host so I can see the gcode it sent, but the time estimates are WAY off, looking for a better workflow.
Is estlcam CNC good or should I start somewhere else?
What control board are you using?
All the ones we sell and recommend do not need a sender.
SKR, I have the Jackpot, but saving it for the LR4.
Is the process just putting the gcode on the sd and running from the machine mostly then?
I setup the wifi stuff from awhile ago, but my connection in the garage is not great so it kept losing connection.
Yup Rock solid that way.
