Filling tubes - a test
@stpdhurts previously tried filling the tubes with an epoxy aggregate Concrete filled tubing “The added strength was not enough to compensate for the extra weight and the deflection actually got worse.”
Another user found that “I filled the static tubes with epoxy concrete for crush resistance (the only easily available 25mm tube around here is the kind you hang curtains on, chromed 0.5mm wall thickness steel tube; it is flexible enough to be deformed by the bearings, and tends to become a bit sloppy eventually); the filling did achieve the “crush resistant” goal, dampens vibration really well, but I got the concrete composition wrong (gravel too large, not enough fine sand, maybe not enough epoxy), so after a few trips of the gantry the exterior steel took the shape of the underlying pebbles / small voids and looks like the surface of the Moon” Concrete filled tubing
