I am using Estlcam to generate my gcode. I will generate some code from a simple part and go to run it. It starts and then just seems to hangup. I then checked the code in a text editor and noticed that the G01 portion of the code was missing from a majority of the lines. Just to check, I added the G01 command to the lines that didn’t have it and then ran it. It worked and I cut the part. Am I missing something. I thought that every line of code needed a command. Any help would be appreciated.
