Are we able to run Estlcam over the network. I am only able to see where a USB cable is required.
I am running my LR 4 on my home network.
Do you mean using Estlcam as the controller? I don’t think the supported boards have network connectivity…
I use Estlcam to make gcode for my Duet Wifi controlled machines. I export gcode files, and then upload them to the boards, where I can run them. I have also uploaded to a Jackpot, and SKR Pro machines with the ESP01S modules to have wifi connectivity.
Yes, that is what I have been hoping to be able to do but I don’t see any options for it so I guess it is not possible.
Darn the luck
You can use fluidnc over wifi like if its wired, you just need a virtual com port linked to an static ip of your cnc controller. That said: estlcam i think doesnt work directly with fluidnc. If its possible to work with usb let me know and i can point you to how connect the controller and the virtual com port on your pc (that said: yo must have a bullet proof connection between devices
My signal strength is 100%, router is maybe 20 feet straight shot from the CNC.
I am able to get Easel to connect to and see the Lv4 but it also doesn’t show the jog controls. I am wondering if I have something setup wrong on my end. I am using Easel and would be happy if we could get it to control the machine.
Just for FYI, I am able to control the machine through Fluidnc over the network with no issues at all.
Sorry i’ve never used that software. It is possible to jog from software because i have done it with lightburn.
I am waiting on Millmage to be released. I am an advanced user of LIghtburn, really like that piece of software.
Do you know what port Fluidnc uses for their WIFI connections? I am able to setup Gsender but it is calling for port 8000 and continues to fail to connect while I am able to connect with the fluidnc.local call.
By default, TCP/telnet uses port 23. If it is using websockets, default is port 81.
http://wiki.fluidnc.com/en/features/wifi_bt#wifi-communication-methods
If the software is capable of recognize a fluid controller with usb connection it will work the way im suggesting. As soon as i gethome will guide you
Thank you Cesar however I think it is time to step back and let the grey matter crunch the numbers for a while. I will be back at it tomorrow if you will be available.
Thank you for all the help!
The building process of the V4 has been one of the most enjoyable challenges I have taken on.
then add the virtual com port (use an static ip -set it prior adding the port- then it will work as if its wired. bullet proof (as long your wifi connection is stable)
Thank you Cesar,
I will give it a go tomorrow. My connection is very stable, hard wired right to the shop! I work from home so my speeds are also very good.
That’s the issue- wireless networking is prone to errors.
Can it sort of mostly work most of the time? Sure.
Does that matter much when it ruins jobs? Up to the user.
The reason sending gcode over WiFi is discouraged is because of that unreliability.
I fully understand that point. I run my lasers with an ethernet hard wired and prefer that to any other option. I am only perusing this option to reduce the number of cables and connections I have to support plus I have been up with my current configuration for over a year and it is rock solid.
If only in a perfect world!
If you set your computer as a hotspot and make your controller to connect to it. It will work. The current normal use depens also of the wifi, and the only way i dont mess up the webpage and hit refreshing in the middle of a job is using: the rpi in KioskMode with a touchscreen and no physical keyboard attached
That said i dont run my cnc with the virtual comport, only the one with the laser attached.
I have UGS up and working so I believe we are good for now.
