This is a bottom the table saw guts that I plan on using for my projects.
At the top of the picture(the threaded rod and sqaure that the motor is mounted to) are the pieces I want to try and use for the drop table. It looks like I might be able to either bolt or weld arms to in order to mount a table/spoil board to. The raising and lowering looks pretty straight forward. I’m going to try and disassemble the part that makes the blade tilt as it won’t be needed.
As far as the lathe parts. I’ve looked at some pictures of diy ones and some of them are belt driven so like still going to look into that. I’m also worried that a dimmer switch won’t be able to handle the draw of the motor
The model of the table saw is a 10" King Feng Fu…
