Do you bring a knife, or router bit, to a fight with magnetic sheets?
Good idea, will check out local maker space(s).
Goal is to work towards this, starting with very small scale project, then front bumper/hood, then go from there…
I use wraps inexpertly quite a bit for odd things.
I can’t imagine it being worth your while to cut with a machine. Just give yourself enough overhang and cut it with a blade - don’t try to be precise, you’ll invariably end up with the panel slightly off and you need room to play.
It’s obvious, but practice on something flat, like all the joinery faces in my van, then move on to trickier parts like the turndown on that curved beam above the drawers. It’s a little bit stressful on the compound bits, but once you get a feeling for the order of shrink and stretch you need to do it’s very satisfying.
