I followed the steps after launching the app however, Got a few questions regarding it.
https://docs.v1engineering.com/software/estlcam-basics/
Initially on the setup it appears it wants us to click english, Says to choose MM units and then MM/per s
Later in the setup looks like it tells us to go back to MM/mins which is what i set mine too also the values for the tools to mms/min.
Followed the rest, It says to change the start of the job at the Origin. Which after completing the setup. It made me a little leary becaue in the crown file at the bottom of the page it showed the G92X0Y0 however, the code that kicked out. Didnt have that and it also had different feed rate, Guessing that came from my tool setup though.
Is this something i should be concerned with? I will attach my code that got spit out. I just wanna make sure all is well. I have to round up another bic pen to rig up for the crown test.
I also didnt hook the computer up to the marlin as i didnt want to risk any issues with my board getting changed.
I did save the settings that I chose for setting it up for the PP It wont let me post those as a attachment. Pretty sure they all match up to the above docs setting…
Estlcrown.gcode (15.9 KB)
^ gcode from Estl after i finished setting tool path
let me know if theres something i missed or should check out.
