Couple of Coasters - on arcade game inspired LR3
Those look amazing, The pocket walls and floors are super clean. Good job!!
Wow, great job!!
Like the arcade inspired LowRider!
Hmmm, questions. How do you know it changed axis?
Also is that just fluidnc accepting input on a pin?
You move and hold the joystick left and right for X axis and forward and back for Y axis. You have to hold down the button corresponding to how far you wish to move 1mm, 10mm or 100mm. There is also a special Z mode which is switched to by pressing 10mm and 100m at same time. LED goes RED then as moving Z is always scary :slight_smile:. Then there are are 3 home buttons, which are a bit cut off in the photo.
This is built using an esp32 with some simple custom code, that connects to an ESP-01 plugged into my SKR Pro controller on the LR3. Connection is via WIFI and uses a very simple REST API that is part of the WEBUI for the ESP-01.
I really like the X-Y movement approach, no accidental move by just bumpinig the stick or pressing a single button, very clever and elegant solution :slight_smile:
