Connecting a Servo to the Jackpot 3
Hi, I’d like to use an externally powered RC servo for the pen-lift mechanism on my pen plotter.
FluidNC supports RC servo PWM on GPIO27. Can I connect it as follows?
  • Servo signal → GPIO27 5V “+”
  • Servo power → external regulated 5V “+”
  • Servo ground and external supply “−” → GPIO27 5V “−”
Is this correct?
Thanks.
I think i’d characterize the signal pin as “PWM” rather than “+5” - that’s how I normally see servo connections documented.
Thanks. I used “5V +” ”5V −”because I was following the labeling on the Jackpot3 board.
Just trying to avoid confusion between “+5v all the time” pins and “adjustable through PWM” pins.
Just to clarify, does this mean my original wiring proposal is incorrect, or were you only suggesting that I describe the GPIO27 terminal as “PWM” rather than “5V +”?
Looks like the wires are in the right place, just saying to describe the GPIO27 as “PWM.”
I haven’t run a servo off the Jackpot, but I’m using PWM on my K40 laser.
Thanks for taking the time to help me. I’ll give it a try and see how it works.
