This pic is the bottom of the LCD case (the part on the print bed):
[attachment file=“IMG_8468 edit.JPG”]
This pic is the top of the case. Notice the difference in the screw holes?
[attachment file=“IMG_8469 edit.JPG”]
Also, I printed out the left and right sides of the case before I noticed this and they are all jacked up as well.
[attachment file=91969]
[attachment file=91970]
Any ideas of what could be causing this? My belts look good and the machine seems to be moving correctly. In Repertier it looks ok as well if you follow the print as it goes, so my computer thinks it’s doing the correct thing and sending the correct gcode to my miniRambo. I’m at a loss and am just going to reboot the damn thing (like any other strange, new computer weirdness). lol.
Edit: in remembering the way I had these laid out in Slic3r (default layout when you load them in Repetier) I think it’s my Y axis that’s gone goofy. I’ll have to check the stepper and make sure there is no slop in the GT2 attached to the shaft. It came loose once before… Does anyone know the correct size of Allen wrench for those tiny little set screws?
