Can't get this to cut!
I’m beyond myself here. Probably both technically and figuratively. I can’t sort what I am not getting done to get my LR3 to zero off the probe, or to load a program to run and start cutting. I’ve updated to the Jackpot and I can’t get it back to work like I had with my Archim board.
Steps I’ve done -
  1. Failed to create a Macro - can’t figure out how to load the g-code into/under a button in the macro dialog - so I gave up and just input via the command prompt - to which the code in my previous topic on probe use, I copied and pasted line by line into the command prompt and it failed.
  2. Decided to just manually set the cutting tool at my zero location and set zero by commands. Seemed fine, until I went to load up a program and I got this in my command prompt:
$G [GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0] ok $Report/Interval=1500 <Idle|MPos:0.000,0.000,0.000,0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000,0.000,0.000,0.000> [MSG:INFO: Channel auto report interval set to 1500 ms] ok <Idle|MPos:0.000,0.000,0.000,0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000,0.000,0.000,0.000> [GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0] $SD/Run=/1-CNCFinals/M&DUrn2.gcode [MSG:WARN: Low memory: 14376 bytes] [MSG:WARN: Low memory: 14256 bytes] [MSG:WARN: Low memory: 14064 bytes] [MSG:WARN: Low memory: 13864 bytes] [MSG:WARN: Low memory: 13736 bytes] [MSG:WARN: Low memory: 12328 bytes] [MSG:WARN: Low memory: 12128 bytes] [MSG:WARN: Low memory: 12004 bytes] <Idle|MPos:0.000,0.000,0.000,0.000,0.000,0.000|FS:0,0|Ov:100,100,100> ERROR:66 error:66 Error : undefined :undefined
Oh, one more thing I did before these two items, I went into EstlCam and did the steps from the Jackpot docs, adjusted from Marlin to GRBL and then uploaded and load the settings as indicated from the steps. I re-tooled my design thinking I ought to do this so Estlcam will set it up for the GRBL g-code. But then I got that code above.
Why are you trying to make a macro? Use a starting and ending gcode.
I replied in the other thread with my pp.
I see that. It felt like the Probe and getting going were two separate items, so I started this thread.
