Hello,
All the parts are printed, fews things should be delivered soon (GT2 stuff)
I still have not made my decision about the size.
Burly is mounted on a 4080 alu frame (stiff enough and not too heavy to be moved or store with no warp) and the dedicated feet MPCNC Burly or Primo 4040 Profile Feet (With Heavy Duty addon) by Naiki - Thingiverse
Because of the different design, my stainless pipes doesn’t fit the 4080 alu frame anymore.
I don’t want to cut the 4080 beams (not equiped to do it ultra clean and as straight as they are)
I’ don’t want to buy another expensive stainless set (price really rised up !!!)
I can imagine assembling the 4080 beams in a different way and design new feet (not in the corner anymore) or, easier, I could print/machine/make some pipe extensions (we are speaking about 1" or so on each end, they will be trapped in the corners)
Depending on how I’ll built theses extension I may loose rigidity.
Does anyone already got through this and went this way ?
Any result to share ?
thanks
My mistake.
I guess at first my interrogation was not very clear but in addition I read the wrong line.
Difference Pipe Vs Table X and Y is only 34mm, so 16mm on each edge.
I’ll find a way to adapt the frame, I’ll make the Y beams closer and will slightly mod the feet base, 2 of them at least.
Well, forget my question
