Hi
Whats the actual build size using the original design? I’ve read somewhere that it was 200mm X 200mm but the Z was less that 200mm.
Thanks
Hi
Thanks
I get 170 in the z direction. But my bed plate is 1/2 thick and i routed my wires out the side instead of over the top. Youd get more if you fillowed the build plan. But i havent needed more even when printing spitfire wings.
I’m really close to an 8" cube with mine, though I did have to work through some issues with wiring catching at inopportune moments when closing in on the top.
