Blue Steel - PrintNC build in Oldenburg, Germany
Could also put more beech veneer on top ^^
Nah, not worth the return. Just not doing those any more.
I wonder if you could reduce tearout with a “scoring” pass of like 0.2 mm before making the cutting passes. I’ve seen saws that have a second blade in front of the first to score the plywood veneer before the main blade cuts it.
I’ve been cutting from some new-to-me plywood with a very thin veneer as well. Thinking this through has give me some ideas to try. Thanks for sharing.
I though about doint a 3mm pass with the downcut, but seriously, the ply is discoloured after oiling. It’s absolute trash. :smiley:
The real power play would be to use ai to read position, harmonics, load etc and constantly adjust your feed and speed accordingly. The closed loop is begging for it.
