Image says more than thousand words…
Do you have a bigger image? Is the issue where it is being cut? What software are you using to generate your gcode? Are you printing, milling, laser, drag knife, foam cutter, plasma cutting?
Sorry for images my bad.There is a pictures of print preview and of movement. I dont know what do to.
What software did you use to make the g-code? Also, can you post the g-code?
What exactly is the issue? Just that the cut is showing outside of the work area? If that’s the case that’s not a issue really.
It cuts and in the middle of procces it loose movement and go wrong
We are going to need a lot more information.
A picture or video really helps.
What hardware and electronics are you using? What software and settings?
Lets see the g code.
