Skr pro v1.2 i can home x and y axis individually but when i use the auto home feature i cant get any motion after that then the tft shows an error failed to home.
For what machine?
Mpcnc[quote=“carlos vergara, post:1, topic:38195, full:true, username:Carlos1”]
Im sorry this would be the primo with end stops at the x and y axis.
There are no Z endstops so you can not auto home. Auto home = home x, then home Y, then home Z.
Take a look at the milling basics page for how we typically use endstops.
Correct no end stops on z axis only x and y axis i can home each x and y individually bia tft or pc and have motion in the correct direction but when i auto home all axis together machine goes to x zero and y zero and squares itself correctly but i am not able to move either x or y axis after it is completed through the tft display or my pc after a few minutes the tft will show a homing failed error, if i home each individually via tft or pc i am able move both x and y axis the full length and width of the machine.
Maybe i misunder stood because ther are no end stops on z axis i cannot use this function is this correct?
Because there is no Z axis.
You cannot use home all.
Have a look at the milling basics page for the starting gcode and how we actually use homing.
Thank you for your time Ryan
