I know it was 8 days ago but I have an example of where this is a pain. Have you used the text tool in Estlcam? That modal window alone needs undo functions. If you change the text size more than once you get bad things happening. Then if you click ok and don’t have something set right your entire text will disappear so you can’t edit it. You have to start over because it’s just gone.
If you’ve ever created a big path by hand and messed up the very end of it, you’d understand why deleting a path and starting over would suck.
Can use Backspace key to “undo” points on a path actively being defined.
But even today, for other operations, ctrl+Z will not undo changes in a way you’d intuitively expect.
