I know this is a stupid question, but just want someone else to also say it’s fine.
There is no issue with running 24v LEDs directly to the power plug of the jackpot board, is there? I know if the LEDs were 12v, they’d need a converter from 24 to 12, but in this case, it should be able to be wired directly with no issue?
You may want to dim the leds to save on heat, but you could do directly if you want as they are 24v. You need to watch the amps drawn by the leds and not exceed whats left from the psu.
