is the 1.5 spindle to heavy for the LR3? I’m getting a lot of deflection the in y-axis or if I upgrade the XZ Plates to the steal would it improve it?
I run a Vevor 1.5kw air cooled 65mm spindle on my full sheet LR3 and I don’t get any noticeable deflection out of it. Is your core tensioned correctly? Are your belts super loose? Any pics or video you have to show the problem would be a big help
Do you have nema 17 motors? Is weight a problem? How much do you have with your 1.5kw spindle?
Yes Nema 17 motors. My machine uses all V1 hardware and Jackpot control board. My beam is 1450mm and has heavy 1/4" aluminum struts on it. I did have to bump the current a little bit but not by much.
