1/4" to 1/8" bit adapter advice needed.
I’m using a Makita 700 that accepts a 1/4" shank. What is anyone using as an adapter to get to a 1/8" 2 flute upcut?
Or are you using a stepped bit? I found this one, but it is a bit shorter than I would like.
My 16th inch bits have a 8th inch shank. Just need to find one with a long enough cutting area. Or find an appropriate collet.
Maybe?
http://m.elairecorp.com/site/makitaroutercollets.html?imz_st
Cool, Interested in the exact collet or bit people are using.
I found this yesterday. http://drillbitsunlimited.com/14-to-18-Collet-Adapter-P4895344.aspx
not exactly sure if this is what you are looking for.
Benjamin,
I just ordered the 1/4 to 1/8 adapter below from Mlcswoodworking I will let you know how it works.
Collet Adapter
Once I ordered that at one I figured the one from inventables below might have less run out as it has multiple grooves.
Inventables Adapter
I’ve been using that Elairecorp adaptor linked by Barry for my Makita. It is a bit pricey but works great. Let us know how the cheaper one works out.
